Jbb13
May 13, 2022Aspirant
Can’t connect locally to Orbi RBR750
Hello, I’m at my wits end and hoping someone can help. I have centurylink fiber internet, and I’m unable to use my Orbi RBR750 until I plug in centurylink credentials on my Orbi via Orbilogin.co...
- May 23, 2022I was able to fix now that I could access the GUI via the following steps I found on another thread. Please note, it wouldn’t connect until the vlan was set.
I still have one outstanding question. Should I set my PPoE credentials to be “always on”?
STEPS TO FIX
Call Centurylink for your pppoe username and password and vlan number which is (201)
Have laptop and ethernet wire (I did mine via phone)
Log on to orbilogin.net (I did mine via 192.168.1.1)
On Basic tab
Make sure you have to the most updated firmware on your router and satellite
Once you determine your software is up to date
Enter your internet service provider pppoe and password
Go into your Advanced tab
Advance setting change to vlan to 201
Follow orbi instruction on set up
Your internet should connect
KevinLiT
May 17, 2022NETGEAR Moderator
Hello Jbb13 ,
I am sorry to hear you are experiencing issues connecting to your Orbi via WebGUI. We understand this is an issue we are working diligently to find a solution. Please navigate to the links below for further information.
For updates via forum please navigate to:
For the status of this issue please visit:
We will do our best to keep you informed on the progress in resolving this issue!
Best,
Kevin
Community Team
Jbb13
May 23, 2022Aspirant
STEPS TO FIX
On Basic tab
STEPS TO FIX
On Basic tab
- FURRYe38May 23, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
