ManOnline
May 19, 2020Aspirant
Can’t download files unless they’re over HTTPS
It seems like a weird problem, but it’s extremely annoying. If I try to download a file like a PDF from a website, it grinds to a halt mid download and fails. If the websites support https and I downl...
May 20, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here by chance? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
ManOnline
May 20, 2020Aspirant
Firmware version is V3.2.11.2_1.2.13.
I’m not at it right now, but it’s one of the AT&T Pace modems I believe. I have the Orbi in DMZ+ and all the WiFi turned off.
It’s the same setup as all my previous routers have used. I’m upgrading from a different mesh router because my router died out of warranty and I can’t replace it without replacing the satellites too.
- FURRYe38May 20, 2020Guru - Experienced User
Ah, seen others with problems with Orbi connected to PACE modems and there DMZ before. I recommend you ask your ISP to upgrade your modem to an Arris if possible.
For now, try this, disable the DMZ+ on the PACE modem and configure the Orbi AX RBR for AP mode.
This should fix what your seeing.
- ManOnlineMay 20, 2020AspirantI tried that yesterday and had other issues. I’m currently replacing it with a different mesh router now, and having no problems. It’s not as fast, but I’ve spent a week with bad WiFi with my old device and this now and can’t keep debugging internet problems instead of working.
Ok. Something is happening with your system and your modem then. Others have not seen this issue. Same for me.
Possible you may have a faulty RBR.There is newer FW available that you can try.
