ManOnline
May 19, 2020Aspirant
Can’t download files unless they’re over HTTPS
It seems like a weird problem, but it’s extremely annoying. If I try to download a file like a PDF from a website, it grinds to a halt mid download and fails. If the websites support https and I downl...
ManOnline
May 20, 2020Aspirant
Firmware version is V3.2.11.2_1.2.13.
I’m not at it right now, but it’s one of the AT&T Pace modems I believe. I have the Orbi in DMZ+ and all the WiFi turned off.
It’s the same setup as all my previous routers have used. I’m upgrading from a different mesh router because my router died out of warranty and I can’t replace it without replacing the satellites too.
May 20, 2020Guru - Experienced User
Ah, seen others with problems with Orbi connected to PACE modems and there DMZ before. I recommend you ask your ISP to upgrade your modem to an Arris if possible.
For now, try this, disable the DMZ+ on the PACE modem and configure the Orbi AX RBR for AP mode.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
This should fix what your seeing.
- ManOnlineMay 20, 2020AspirantI tried that yesterday and had other issues. I’m currently replacing it with a different mesh router now, and having no problems. It’s not as fast, but I’ve spent a week with bad WiFi with my old device and this now and can’t keep debugging internet problems instead of working.
- FURRYe38May 20, 2020Guru - Experienced User
Ok. Something is happening with your system and your modem then. Others have not seen this issue. Same for me.
Possible you may have a faulty RBR.There is newer FW available that you can try.
