BeeDubs
Oct 04, 2024Aspirant
Can’t get to advanced settings Orbi RBK763
I need to set my Orbi up using my provider’s PPPOE settings (IINET). I also need to change the Bridge/VLAN settings. Using the Orbi app, I can get as far as adding the PPPOE user name and password ...
- Oct 13, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oct 06, 2024Guru - Experienced User
Using the Orbi app, I can get as far as adding the PPPOE user name and password but have no access to advanced settings.
Supposedly if I use orbilogin.com, or the direct router address, this should give me a login prompt and then allow me to access advanced settings, but I don’t get a login screen as the setup wizard immediately kicks in. This doesn’t allow me to choose any other option other than giving it the old MAC address (which doesn’t work.)
Any advice gratefully received!
