Sameem
Jan 14, 2025Aspirant
Can’t login to RBS750’s
Hi Guys, I currently have an RBR750 with two satellites. I can login to my router fine using 192.168.1.1 and can see both satellites connected with a good connection. When I enter my satellite...
Jan 14, 2025Guru - Experienced User
you've tried what I'd recommend (in terms of password options).
make sure there isn't any spaces and maybe try a different web browser. Also disable any password managers.
- SameemJan 14, 2025AspirantI tried a different browser. Also went to private browsing mode and still the same 😞
- plemansJan 15, 2025Guru - Experienced User
and you're sure the satellites are on the same firmware as the router? I've read of issues accessing them when they aren't
- SameemJan 15, 2025AspirantI swear to god they all are. When I log into the router (just not home right now to show proof) they are all the same firmware version 😞
