Sameem
Jan 14, 2025Aspirant
Can’t login to RBS750’s
Hi Guys, I currently have an RBR750 with two satellites. I can login to my router fine using 192.168.1.1 and can see both satellites connected with a good connection. When I enter my satellite...
Jan 14, 2025Guru - Experienced User
you've tried what I'd recommend (in terms of password options).
make sure there isn't any spaces and maybe try a different web browser. Also disable any password managers.
Sameem
I tried a different browser. Also went to private browsing mode and still the same 😞
- plemansJan 15, 2025Guru - Experienced User
and you're sure the satellites are on the same firmware as the router? I've read of issues accessing them when they aren't
- SameemJan 15, 2025AspirantI swear to god they all are. When I log into the router (just not home right now to show proof) they are all the same firmware version 😞
- plemansJan 16, 2025Guru - Experienced User
When you reset, did you hold the power button while powered on for up to 30 seconds? (on the satellites)
Try that and then see if you can manually sync the satellites versus letting the stock link from kits work.
https://kb.netgear.com/31018/How-do-I-sync-my-Orbi-router-and-satellite
