Fishfriendz
Feb 18, 2025Aspirant
Can’t roll back firmware update on RBR750
Hello I made the mistake of upgrading my RBR750 and now my RBS350 satellites are having issues. Based on what I read I need to roll back to a non v7 update. When I try to download from NETGEAR and ...
Feb 18, 2025Guru - Experienced User
Just open the .zip file then use the RBRs web page to send down the .chk file to downgrade the RBR back to v4 version of FW. Once it's downgrade, then you could update the RBS to now supported v.31 FW first, then get the RBR back to same version.
