Events1968
Jul 20, 2023Aspirant
Can anyone help me... Orbi RBK762S will not connect to internet
No matter what I do it keeps saying "no internet"
Events1968
I have Sky Ultrafast Broadband, removed the rubbish router and replaced with Orbi
- FURRYe38Jul 20, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Check with the ISP to see if they require any WAN side configurations, like Static or PPPoE.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.- Events1968Jul 21, 2023Aspirant
- schumakuJul 21, 2023Guru - Experienced User
The Sky supported device does more, in some aspects much more than a plain Ethernet connected DHCP WAN router can do.
Your ISP does require MER (DHCP Option 60/61) for Sky FTTC in the UK to start with connecting third-party routers like the Orbi. Sometimes, it's even required to duplicate the original router MAC address.
Well possible, the Sky supplied CPE (customer premise equipment) device must remain in place, for example to provide POTS phone port.
What is best course of action?... Have I wasted my time purchasing the Orbi?
Can anyone advise a newbie here what to do?
I'm going to try and do what Furrye38 suggested today to start... he was very helpful- schumakuJul 21, 2023Guru - Experienced User
No idea where my previous reply disappeared.
One point worth mentioning: Keep in mind, the Sky Internet calling (Sky VOIP service) is available only with the phone plugged into the back of the hub, there are no VOIP settings you can use with any VOIP type phones. This feature would be lost replacing the Sky supplied CPE.
For the free Netgear complimentary 90-day tech support, please don't hesitate to contact Netgear customer support via https://my.netgear.com/ - they -should- be able to guide you through the installation of your Orbi system on your Sky Ultrafast Broadband connection.
