Events1968
Jul 20, 2023Aspirant
Can anyone help me... Orbi RBK762S will not connect to internet
No matter what I do it keeps saying "no internet"
Jul 20, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Check with the ISP to see if they require any WAN side configurations, like Static or PPPoE.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Events1968
Jul 21, 2023Aspirant
- Events1968Jul 21, 2023Aspirant
