Events1968
Jul 20, 2023Aspirant
Can anyone help me... Orbi RBK762S will not connect to internet
No matter what I do it keeps saying "no internet"
schumaku
Jul 21, 2023Guru - Experienced User
The Sky supported device does more, in some aspects much more than a plain Ethernet connected DHCP WAN router can do.
Your ISP does require MER (DHCP Option 60/61) for Sky FTTC in the UK to start with connecting third-party routers like the Orbi. Sometimes, it's even required to duplicate the original router MAC address.
Well possible, the Sky supplied CPE (customer premise equipment) device must remain in place, for example to provide POTS phone port.
Events1968
Jul 21, 2023Aspirant
What is best course of action?... Have I wasted my time purchasing the Orbi?
Can anyone advise a newbie here what to do?
I'm going to try and do what Furrye38 suggested today to start... he was very helpful
- schumakuJul 21, 2023Guru - Experienced User
No idea where my previous reply disappeared.
One point worth mentioning: Keep in mind, the Sky Internet calling (Sky VOIP service) is available only with the phone plugged into the back of the hub, there are no VOIP settings you can use with any VOIP type phones. This feature would be lost replacing the Sky supplied CPE.
For the free Netgear complimentary 90-day tech support, please don't hesitate to contact Netgear customer support via https://my.netgear.com/ - they -should- be able to guide you through the installation of your Orbi system on your Sky Ultrafast Broadband connection.
- Events1968Jul 21, 2023Aspirant
Thanks for reply schumau
The line is just for broadband (no phone)
I was looking into what you mentioned regarding 'option 60/61' and it's obvious now I require this... I don't think my unit has this facility so it might be best to return it which is a bit disappointing!- FURRYe38Jul 21, 2023Guru - Experienced User
One could use the ISP router to handle the ISP WAN configuration and either configure the Orbi system or AP mode or use the Orbi system in router mode and use the DMZ on the ISP router for the Orbi router.
