mbt90's avatar
mbt90
Tutor
Mar 13, 2023
Can connect to satellite but not router
First post here, and a newbie so apologize if information is missing. Anyway, here goes: Setup: Modem --> RBR750 --> RBS750   Problem: Have been running smoothly until a couple of days ago, where ...
  • mbt90's avatar
    mbt90
    Mar 13, 2023
    I just saw that a firmware update was pushed a couple of days ago, a factory reset seems to have done the trick.
    What modem is it? No idea, something supplied by the internet supplier. I have fiber internet.
    What firmware is on the router and on the satellites? The latest, I can see that an update was pushed approx. 4 days ago.
    Do wired devices on the route work fine? No wired devices.
    What switch do you have? No switch (yet)
    And its setup using a wired backhaul? It wasn't, it is now 🙂
    Is the satellite wired into the lan port of the router? It is now. Is that not basically the same question as above?
    Can you recommend a non-managed, non-green switch that is not quite as expensive as yours? 😄
