jlapl169
Dec 27, 2022Follower
Can I add a new RBS750 to my older RBK53 Mesh system?
I am trying to decide to add another satellite to my current mesh setup. Can I add a new RBS750 to my older RBK53 Mesh system? If so, is it easy to get them all setup together?
Dec 28, 2022Guru - Experienced User
as CrimpOn says, no, it won't work.
But there's a bunch of renewed 40 and 50 series orbi's on amazon. Cheaper than buying the satellite by itself and then you have a backup router in case the main router ever goes bad and then you have a bunch of satellites you can't use.
