jvon33
Apr 14, 2020Aspirant
Can I Add Ex8000 Mesh to Orbi Ax6000
I have a two story 3500 sq foot home with a detached garage. My Gateway Modem is a Comcast Xfi 6. I would like to Plug in Orbi Ax6000 (rbk852) router to the Gateway Modem which is upstairs in the m...
jvon33
Thanks Furrye38! That is great informaiton to know!! It seems the Ax6000 isnt perfected for my wishful solution yet.
I have to use the Comcast Modem xfi6 in Wifi mode because of our security system.
So if i understand this correctly:
Because Comcast Modem xfi6 has to be in Wifi mode, the Orbi Ax6000 Router needs to be AP mode.
Orbi RBR in AP Mode
- You can't have a switch between RBR & RBS (unless netgear can resolve this issue)
- I can connect RBR & RBS wirelessly - but 30 feet between units isn't much given a 2 story 3500 sq ft house
Switch between Comcast Xfi6 and Orbi RBR - rooms hardlined in from the Comcast Modem
- This configuration the Orbi RBS can't be hardwired in - it can't communicate to the RBR (which makes sense)
- This configuration i could setup RBR and RBS wirelessly to each other.
Bummer on the Ex8000 that I purchased 6 months ago, I wish know I would have boughten the orbi Outdoor, that should work with the Orbi Ax6000, correct?
Currently, I guess the best solution is:
- Connect the Comcast Modem/Router Xfi6 to the Orbi Ax6000 WAN Port
- Use the RBR's 4 Lan ports as a switch & pick the 4 most important rooms
- Once hopefully NG resolves the switch issue, I can then utilize the switch to hardline in more rooms in the house
Thanks!
Apr 14, 2020Guru - Experienced User
If you want, yon can downgrade FW version to v3.2.9.2 which works for wired RBS with a switch in the middle in AP mode.
Or you can use current FW and use the Orbi in router mode and use the modems DMZ for the RBR in router mode. This would help with having two routers on the same line if you want to use the RBS wired with a switch.
30 feet or more is preferred. I have a 5000sq ft home, RBR at one end on 2nd story and RBS down at the other end in the basement. 40 feet in between. I get a poor reading here however RBS will works ok when wirelessly connected. Great when it's wired of course.
