Marian_P
Oct 13, 2025Guide
Can I change the wifi channels on the Orbi Mesh/RBK862SB?
Hey, I'm considering changing the router. The current model is a 2-pack Deco X60/AX5400. While it works most of the time but the smart devices keep disconnecting and connecting. This Christmas, I'll ...
- Oct 14, 2025
Marian_P wrote:
Does RBK862SB allow me to manually change the wifi channels, especially for the 2.4ghz band?
Yes, you can set up fixed channels for both the 2.4 ghz and 5 ghz client radios. There is a control to enable (or disable) 20/40 Mhz coexistence, but you cannot set up the channel to only use 20 Mhz. (The control either enables 40 Mhz or both 20/40).
You won't have control over the radio used by the mesh backhaul (used to connect the satellites to the router).
More details are here:
- https://www.downloads.netgear.com/files/GDC/RBK863S/RBR860_RBS860_UM_EN.pdf
Oct 14, 2025Guru - Experienced User
Marian_P wrote:Does RBK862SB allow me to manually change the wifi channels, especially for the 2.4ghz band?
