dklimas
Mar 13, 2021Apprentice
Can I ethernet connect the old RBR50 in AP mode to the new RBR850 and broadcast the same SSID?
I upgraded my AC3000 mesh to the AX6000 mesh. I want to continue to use my Orbi Voice in the garage to listen to music and turn lights on/off with Alexa. Can I connect the RBR50 router to the new sys...
- Mar 13, 2021
Something you can try bug it may cause problems. You should set a different SSID name and be sure to use far separate channels on each RBR. 1 for 2.4Ghz and 11 for the other. Same with the 5Ghz radios.
dklimas
It did indeed work (Alexa works too) but I did notice I don't have any Voice control settings in the app for the RB40V like I did before. Not a deal breaker. I'm just glad I can control smart devices in the garage through the RB40V. I also didn't see a way to hide the RBR50's SSID like I could prior to upgrading to wifi 6.
Mar 14, 2021Guru - Experienced User
Glad you got it working.
Ya, hidding SSIDs are not supported on Orbi AX.
Enjoy. :smileywink:
- dklimasMar 15, 2021Apprentice
FURRYe38 wrote:Ya, hidding SSIDs are not supported on Orbi AX.
So it's more of an app thing and not a hardware thing? Or because the RBR50 is behind the RBR850 and in AP mode the RBR850 rules apply?
- FURRYe38Mar 15, 2021Guru - Experienced User
A UI issue thats not seen on Orbi AX.
