SusyH
Sep 26, 2020Aspirant
Can I hook a legacy Ethernet Printer/Scanner/Copier to Orbi mesh network using a satellite unit?
Actual Model: Orbi RBK753S-100NAS, satellite:RBS750, AC4200 series (not in your choice menu). I have just ordered the 3 piece Orbi Tri-band and I was hoping that I could order an additonal satellite ...
- Oct 04, 2020
Glad it's working well now for you. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Sep 27, 2020Guru - Experienced User
Be sure to visit the Orbi AX Forum for additional help and information.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Yes you can connect wired periferals to the RBS
Good Luck.
SusyH wrote:Actual Model: Orbi RBK753S-100NAS, satellite:RBS750, AC4200 series (not in your choice menu). I have just ordered the 3 piece Orbi Tri-band and I was hoping that I could order an additonal satellite and connect our large business legacy Ricoh printer/copier/scanner to the satellite to join the network and be used by wireless and wired devices on the network. Right now it can only be accessed if you are connected on the wired part of the network, the wireless devices can't access it even though they are going to the same router(cable modem combo). Inshort the Ricoh has no wireless capabilities, but it does have an Ethernet connections. This is not a inexpensive home printer that is easily replaced, and we need the capabilities of this printer. Any suggestions or information would be helpful. Thank You, SusyH.
