onlize
Jan 20, 2022Aspirant
Can I set up a preferred satellite?
Hello, I have an Orbi 750 router and satellite. I have multiple devices located near the satellite device, but they connect to my router. I know that devices support a mesh environment because, f...
CrimpOn
Jan 20, 2022Guru - Experienced User
No. There is no method to dictate the specific Orbi unit where a device will connect. (One of the most frequently asked questions.)
One would presume that the device will not connect to an access point that does not offer adequate performance. For example, a security camera may need less than 10mb/sec to stream video (even less if it is streaming to a smartphone app). Streaming 4K video requires 25mb/sec, which is well within the capacity of 2.4G WiFi.
If the device does not function satisfactorily when connected to the router, sometimes it will 'switch' if turned off and back on again.
