onlize
Jan 20, 2022Aspirant
Can I set up a preferred satellite?
Hello, I have an Orbi 750 router and satellite. I have multiple devices located near the satellite device, but they connect to my router. I know that devices support a mesh environment because, f...
Jan 20, 2022Guru - Experienced User
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
onlize wrote:
Hello,
I have an Orbi 750 router and satellite. I have multiple devices located near the satellite device, but they connect to my router. I know that devices support a mesh environment because, for example, I have the same cameras. Some of them connect to the satellite, but some of them connect to the router.
Is there any way to set up the preference for the connection? I want them to connect to the satellite because it should give me better performance.
onlize
Jan 21, 2022Aspirant
Hi, the firmware on my satellite is v.4.6.5.14.
The firmware on my router is v4.6.5.14_2.0.54
Distance would be about 30ft, but they are located on different floors.
Which option should I set to 50%? I see "Transmit Power Control" under Region Selection and Advanced Wireless Settings.
This is the first time I am trying to post a picture on this forum and, for some reason it does not show the picture correctly.
- FURRYe38Jan 21, 2022Guru - Experienced User
Yes, adjust the Transmit Power Control drop down menu.
- CrimpOnJan 21, 2022Guru - Experienced User
Adjusting Transmit Power is sort of a "blunt instrument". This setting alters the user radio channel of every Orbi unit, which will shrink the area with strong coverage for every Orbi device. If there are other devices which now get a strong signal and connect at a high "link rate", but are not particularly close, their link rates may drop. An attempt to make one satellite more attractive than the router for this particular device may have unintended consequences.
It can be a bit of a 'bother' to collect before and after records of individual device link rates. On the Orbi app, one would have to open the Connected Devices display, then press on each device to bring up the link rate, record the value, go back, open the next device, etc. etc.
If you happen to have Microsoft Excel, there is a spreadsheet which will collect all that information in one place.
- onlizeJan 21, 2022Aspirant
I understand that I must change Transmit Power Control, but where? There are two sections with this setting. One of them is "Region Selection" and another one is "Advanced Wireless Settings..."
Which one?
