onlize
Jan 20, 2022Aspirant
Can I set up a preferred satellite?
Hello, I have an Orbi 750 router and satellite. I have multiple devices located near the satellite device, but they connect to my router. I know that devices support a mesh environment because, f...
Jan 21, 2022Guru - Experienced User
Yes, adjust the Transmit Power Control drop down menu.
onlize
Jan 21, 2022Aspirant
I understand that I must change Transmit Power Control, but where? There are two sections with this setting. One of them is "Region Selection" and another one is "Advanced Wireless Settings..."
Which one?
- FURRYe38Jan 21, 2022Guru - Experienced User
Under Advanced Tab/Advanced Settings/Wireless Settings
- onlizeJan 21, 2022Aspirant
FURRYe38 wrote:Under Advanced Tab/Advanced Settings/Wireless Settings
Please take a look at the picture that I attached. It shows that there are two options with the same name "Transmit Power Control" under Advanced/Advanced/Wireless Settings. Which setting to use?
- CrimpOnJan 21, 2022Guru - Experienced User
One is for the 2.4G radio. Other is for the 5G radio.
