Carlos84
Jan 30, 2023Aspirant
can I use 2 rbk852 ?
I can buy 2 rbk852 cheaper then 1 rbk853 and now my question is if I can connect them together? and how? does it work without lan cable?
Jan 30, 2023Guru - Experienced User
Not really.
The two systems would work separately.
Or you could take the RBS from one set and connect them to the other.
The RBRs can only work in router mode or AP mode so you could connect the 2nd RBR however it would be it's own SSID network and not integrate into the other systems MESH.
- plemansJan 30, 2023Guru - Experienced User
If its cheaper to buy 2x RBK852's versus one RBK853, I'd do it.
You can use the satellite for the other system and have a backup router in case one goes bad.
Or you could sell the router to recoup some costs.
