Carlos84
Jan 30, 2023Aspirant
can I use 2 rbk852 ?
I can buy 2 rbk852 cheaper then 1 rbk853 and now my question is if I can connect them together? and how? does it work without lan cable?
Carlos84
In germany we have thick Stone walls. XD in my 10meters far room i only have 2.4ghz
Jan 30, 2023Guru - Experienced User
I see. Well for that, you may want to review getting some ethernet cabling installed or maybe go with some power line adapters and connect the RBS to the end of the PL where you need the RBS placed.
