tjm1962
Apr 30, 2022Aspirant
Can I use a mesh network to provide wired interent?
I'm using wireless internet (T-Mobile). But I live in a rural area and have to place the T-Mobile modem in a barn to get a good signal (barn has a good one of sight view of the cell tower). Is th...
- May 23, 2022
I got my configuration up and running.
T-Mobile Home Internet in the barn, with ethernet cable going to RBR, which is placed in front of a single pane window.
RBS in line of sight of RBR, about 70 feet away, in front of a dual-pane window.
Additional RBS on other side of house.
No wired backhaul.
Backhaul status for 2nd satellite listed as poor, but still seems to have good connectivity.
I have connected the 1st RBS to my wired network in the house, which goes to a netgear switch (GS316).
Attached to the netgear switch is a AC1000 wifi router that devices in my basement use. Not important, I just wanted to point out that the RBS did handle connecting to my switch and the ability for other routers/access points to use (which I confirmed with Netgear support).
However, speed tests when connected to the AC1000 were low (20 MB/s), so that would not be a viable method for everyday use. It works for me because the devices down there (water leak detector, energy monitor) are low bandwidth.
I connected a single device (laptop) to the 2nd satellite via ethernet and did not see the same speed reduction, the speed seemed appropriate for the backhaul status being reported (around 100 MB/s).
It appears that the wifi of the Orbi is much better than that provided by the T-Mobile Home Network device. When measured back to back I got 125 MB/s from the T-Mobile wifi, and 140 from the Orbi wifi.
Once I had the Orbi I was able to relocate the T-Mobile device to a better location, and I now get results in the 160-200 MB/s for my network (from an iMac located in the same room as the 1st satellite.
Summary: You can connect a satellite to a switch and it will handle multiple connections, but the speed through a router connected to that wired network does not come close to the speed of a direct connection (I only saw about 5 MB/s).
Very happy with my purchase (RBK753), before the rest of the house had very limited bandwidth (could not see the T-Mobile internet device), and now I have excellent bandwidth in the entire house.
Thanks for all the help! Much appreciated.
michaelkenward
May 08, 2022Guru - Experienced User
tjm1962 wrote:
Does it make any sense to try to connect the two or three RBSs with wired ethernet for some kind of backhaul?
I'd say that the previous answer from FURRYe38 also applies here. Try it and see.
We are talking about a set up that isn't common. So there won't be that much past experience to go on.
tjm1962
May 23, 2022Aspirant
No wired backhaul.
