DavidMK
Oct 23, 2020Aspirant
Can I use AC3000 Satellites with AX4200 Router
I currently use AC3000 (1 router + 2 satellites) and thinking about changing to AX4200. Will I be able to use the AC3000 satellites with the AX4200 router? Thanks and stay well!
Oct 23, 2020Guru - Experienced User
Wirelessly, No, wired, Yes.
DavidMK
Hi FURRYe38,
Thanks for your info!
For wired - how do I do this with the satelittles? There are 4 ethernet ports and I assume they are all for connecting the satellite to other devices. Are you saying I can connect from router to one the ports?
- FURRYe38Oct 23, 2020Guru - Experienced User
