BulletRouge
Dec 01, 2020Aspirant
Can I use an AX600 as a router for AX420 mesh points?
OK, so I am soon getting a AX4200 kit (router and 2 mesh points). I am wondering if I'll be able to upgrade the router part at some point to the AX6000 (if they ever sell it alone) and still be able ...
- Dec 01, 2020
Correct.
BulletRouge
OK, so I think what you said was that the AX4200 meshpoints will work fine with the AX6000 router, but that there is no way for the AX4200 router to act as a meshpoint for the AX6000 router?
Dec 01, 2020Guru - Experienced User
Correct.
