Dpuck59
Sep 14, 2021Follower
Can I use my C6250 Cable Modem as only a modem and add on an Orbi as my router?
Hello - I have a 3 year old C6250 cable modem router and would like to increase the "reach" of my wifi throught a large home. Instead of buying a new modem, can I keep the C6250 and "turn off the ro...
Sep 14, 2021Guru - Experienced User
You also have the option of leavef the C6250 in router mode and putting the orbi in access point mode.
You can use the C6250 as a backup wifi or to even offload some of the closer devices to it.
I've used that option before.
Just make sure to have it on a seperate ssid from the orbi and to have it on a different wireless channel to prevent interference.
