MBMT's avatar
MBMT
Follower
Oct 19, 2021
Can I use RBR850 with 2 different ISP's?
I live in a very rural are of the country and currently use HughesNet as my ISP.  Because of latency issues with satellite based internet, I also ordered a SLOW DSL circuit.
Can I use 2 ISP's with the Orbi RBR850 or will I just have to use the wireless router feature on the DSL modem for the DSL and the Orbi wireless feature for the HughesNet?
Thank you.
  • The RBR needs to be connected one mode that has a ethernet connection. It only supports 1 ISP modem device at a time. The RBR supports Link Aggregation however this still has to be with 1 modem that also supports LAG itself. Just combines 2 connections between the RBR and ISP modem that support this feature.
  • FURRYe38's avatar
  • It will not work with it. You will end up needing to put either something like a pfsense/netgear firewall aggregation or a dual wan router/switch setup like the TPLINK ER605 or its successors. That way you can successfuly combine two ISPs
