flyerBob
May 28, 2021Aspirant
can I used the Orbi RBK753S with a fixed STATIC IP?
Can I set up the Orbi 753S with a STATIC IP address? (My current network uses a static IP address, with certain port forwarding. I MUST be able to continue to do this)
- May 28, 2021
flyerBob wrote:Can I set up the Orbi 753S with a STATIC IP address?
Page 22 of the User Manual describes how to set up the Orbi router with a static IP:
https://www.downloads.netgear.com/files/GDC/RBK752/RBK752_UM_EN.pdf
flyerBob
May 29, 2021Aspirant
BTW, is there information on port forwarding? It din't seem to be on that page.
CrimpOn
May 29, 2021Guru - Experienced User
flyerBob wrote:BTW, is there information on port forwarding? It din't seem to be on that page.
page 99
- flyerBobMay 29, 2021Aspirant
thanl you
- FURRYe38May 29, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
Thank you; I couldn't figure out which subset community would be best for my question.
At the moment, I think I have enough information.
