Acct
Jul 28, 2022Aspirant
can not add MAC address in Access Control list for RBK752
Hi, My wifi is Netgear Orbi WiFi RBK752 AX4200. Hardware Version RBR750 Firmware Version V4.6.5.14_2.0.54 I am setting up MAC address filtering in the Security / Access Control. Problem...
Jul 28, 2022Guru - Experienced User
There maybe a limitation on how many you can input in to this section. I've asked NG to see that this limit is.
- AcctAug 05, 2022Aspirant
I don't think it is causing by a limitation, is it application software bug instead ?
as if it is a limitation, I encountered the problem when only entering 2x entries in the list, it is too low and not enough, even a common TPLINK can support up to 64 entry.
