dohc97
Apr 13, 2021Follower
can not connect to VPN
Just got my Orbi RBR750 last week. I can connect to vpn to login to my work using a wired connection. when I am on a wifi connection, I can not connect to my vpn. A workaround I found is to connect ...
Apr 14, 2021Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Does this happen on your one device or others as well?
