ellen2298
Aug 25, 2020Apprentice
can orbi RBR50 and RBR750 run simultaneously
Sorry if I sound really ignorant. This is my first post here and I am sadly a self educated network newbie for my home. We first had google wifi and then switched to the OrbiRBK53 about 1 year ago. W...
ellen2298
Aug 26, 2020Apprentice
My RBK752 is arriving later today so I am trying to make sure I know how to install in AP mode to make it work. I understand once in AP mode the base unit and satellite can't be controlled by Orbi app but do I make a new orbilogin for the RBR750 that will be in AP mode or does it get added in my orbilogin that I currently use for the RBR50?
I will change the channels or both of them as you suggested
You mention about the distances but the RBR50 will be adjacent to the AP RBR750. They will both be projecting wifi but on the different channels. That is okay, correct?
The RBS50 will be 30+ ft away on that floor and the other RBS50 will be on the below floor. The RBS750 will also be on the lower floor but on opposite side of home. Should this be able to avoid the interference issues?
Thanks again in advance!
