ayumi
Sep 07, 2022Follower
Can RBR750 act as satellite?
I think I know the answer to this question but I will ask since we were told that it would work. I already own one router and one satellite (RBK752). A buddy of mine wanted to buy the same setup but...
Sep 07, 2022Guru - Experienced User
It can't act as a satellite.
You can connect it hardwired in and run it in access point mode but it won't integrate with the rest of the devices. Make sure to have its own ssid and on its own channels to prevent interference.
ekhalil
Sep 07, 2022Master
plemans wrote:It can't act as a satellite.
Agree, but I think it should be ok to have the same SSID but on different radio channels.
- plemansSep 08, 2022Guru - Experienced User
You can use the same ssid.
I just find roaming a bit less efficient when ran that route.
but it will work.
