jepper35
Dec 30, 2021Follower
can the orbi router rbr750 work as a satelite in a setup?
i have to Orbi RBK752 AX4200 tri-band mesh wi-fi 6 set and i wonder i i can use one of the routers as a satelite so i get 1 router and 3 satelite?
Dec 30, 2021Guru - Experienced User
RBRs can only work in router or AP mode. Not as RBS.
- FodenJan 05, 2022Apprentice
Aren't the satelite's basically AP's?
- CrimpOnJan 05, 2022Guru - Experienced User
Yes, they are. (Isn't a taxi cab basically a 'car'?)
The difference is that the all mesh systems communicate with each other about which devices are connected and have advanced features to handle the "hand off' from one access point to another.
A normal WiFi access point knows nothing about any other WiFi unit.
It is really irritating that Netgear decided to implement the Orbi system this way. Other vendors who use identical hardware for routers and satellites allow the user to define which unit will be the gateway to the internet and the rest can be satellites. But, Netgear chose to do it this way.
There was one enterprising hacker who discovered a way to change the original RBR50 router into an RBS50 satellite, but thus far no one has come up with a similar method for other models.
And one guy/gal (Voxel) wrote his own custm firmware for their Orbi, but not ours. https://www.snbforums.com/threads/custom-firmware-build-for-orbi-rbk50-rbk53-rbr50-rbs50-v-9-2-5-2-11sf-hw.71395/
I noticed on the debug info you can get from (routerip)/debug.htm that the Orbi's are based off OpenWrt
