bignum
Jun 12, 2020Aspirant
Can the RBK852 use its 2.5Gbps port in AP mode?
Hi, I am considering the RBK852, but I will be using it in Access Point mode. I have an NBASE-T switch (Netgear MS510TX) and I'm wondering if I will get 2.5gbps wired throughput from the Orbi in ...
aronake
Jul 27, 2020Aspirant
I am interested in knowing this too.
If not, would be rather stupid.... but there are many stupid things going on....
Anyone have any knowledge?
- FURRYe38Jul 27, 2020Guru - Experienced User
I preusme the 1 WAN port on the RBR will connect at 2.5Gb to another 2.5Gb port. The other LAN ports on the back of the RBR are only rated at 1Gbs.
- bignumJul 27, 2020AspirantThe answer for now is that, yes, this appears to work. When connected to my Netgear MS510TX it negotiates a 2.5 gbps connection. I haven’t benchmarked the throughput yet however.
Good to hear. I presumed it would. I know i see the higher connection rate between my RBR and CAX80 which supports 2.5Gb on 1 port.
I wish the LAN ports supported 2.5Gb. :smileywink:
