bignum
Jun 12, 2020Aspirant
Can the RBK852 use its 2.5Gbps port in AP mode?
Hi, I am considering the RBK852, but I will be using it in Access Point mode. I have an NBASE-T switch (Netgear MS510TX) and I'm wondering if I will get 2.5gbps wired throughput from the Orbi in ...
bignum
Jul 27, 2020Aspirant
The answer for now is that, yes, this appears to work. When connected to my Netgear MS510TX it negotiates a 2.5 gbps connection. I haven’t benchmarked the throughput yet however.
Jul 27, 2020Guru - Experienced User
Good to hear. I presumed it would. I know i see the higher connection rate between my RBR and CAX80 which supports 2.5Gb on 1 port.
I wish the LAN ports supported 2.5Gb. :smileywink:
