rdouma
May 15, 2022Guide
Cannot access admin panel anymore (Orbi RBR850)
Apologies if this is not the correct channel, I don't see anything else that seems to match my Orbi RBR850. Problem: I discovered today I cannot access the admin panel on the router anymore, nor...
rdouma
May 18, 2022Guide
Thanks for the link. I still hope Netgear will come up with a solution that doesn't require a factory reset. I don't look forward to configuring it again (yes, I should have made a recent backup of the configuration and I didn't) but also I'm just worried that that will really brick it.
May 18, 2022Guru - Experienced User
It won't.
Make contact with NG support and see if they can help you first.
