GCT11
Jan 29, 2024Aspirant
Cannot access Orbi Admin login screen
I have just installed a new Orbi RBK852 and everything is working great except my Trane thermostat. It is connected to my wifi (strong signal), but no internet connection. To solve this problem, I wa...
- Feb 15, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jan 29, 2024Guru - Experienced User
Even with a ethernet connected PC to the back of the RBR and using 192.168.1.1 or try 10.0.0.1?
Check on the connected PC to see what IP address it is getting from the RBR...
Did you set the Orbi system using Orbi app or a wired PC?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
- GCT11Jan 29, 2024Aspirant
Thanks very much for the help. I did get into the Orbi Admin Login and changed the CTS/RTS to 2347, but unfortunately the smart thermostat is still the same - has full wifi, but no internet. I may just have to buy a new model thermostat. Thanks again.
- CrimpOnJan 29, 2024Guru - Experienced User
Perhaps it would be worth a few minutes to investigate a couple of things regarding the thermostat.
How does the Orbi Attached Devices describe the thermostat?
- It appears on the list of devices that are connected?
- It has an IP address?
- Which Orbi unit does it show the thermostat connected to?
- Does the Attached Devices page show that Access Control is "on" or "off"?
(At the top of the page, above the list of satellites)
If Access Control is "on", navigate to the Advanced Tab, Security Menu, Access Control.
How is the thermostat described on that screen? ("Allowed" or "Blocked")
- GCT11Feb 13, 2024Aspirant
Hello again, so sorry I have been gone for awhile and thanks again for your previous responses . I'm finally back working on connecting my Trane thermostat to the internet. I just read another post and someone solved this problem by unplugging the satellite and connecting to the main router. I have tried that and the thermostat now connects to wifi (strong signal), but still has no internet access. It now shows up as an attached device. It has an IP address, a mac address, access control is shown as allowed (not being blocked), but still no internet access. Any additional help would be much appreciated. Thanks.
