GCT11
Jan 29, 2024Aspirant
Cannot access Orbi Admin login screen
I have just installed a new Orbi RBK852 and everything is working great except my Trane thermostat. It is connected to my wifi (strong signal), but no internet connection. To solve this problem, I wa...
- Feb 15, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Feb 14, 2024Guru - Experienced User
Try connecting this device to the IoT network if your Orbi system FW is loaded with v7.x FW.
Something to contact Trane about regarding there product.
GCT11
Feb 14, 2024Aspirant
Thanks again for the response. I do not have v7 firmware on my Orbi RBK850. I took your advice and contacted Trane this morning. After an hour on the phone we were not able to correct the problem of no internet connection. I plan to contact NetGear support and see if they have an answer.
- FURRYe38Feb 15, 2024Guru - Experienced User
Have you set up the separate IoT WiFi network on the RBR and see if it will connect there?
- GCT11Feb 15, 2024Aspirant
Just talked to Netgear support and the issue has been resolved. In my admin account under basic wireless, I had to uncheck the box for AX 2.4Ghz. The thermostat is not AX compatible, so with that box unchecked it will now connect to the internet. Thanks very much for your help.
Enjoy. 📡
