CorrectTangelo
May 15, 2022Aspirant
Cannot Access Remote Plex Server - Unsecure Connection Error
Hello, Hoping someone can offer suggestions on how to troubleshoot this. I just upgraded my home Wifi to a Netgear RBK853 Orbi and I'm no longer able to access my remote Plex Media Server. When ...
May 15, 2022Guru - Experienced User
Verizon is notorious for their "bridge" setting not working properly.
Try leaving the verizon in router mode (disable its wifi) and then put the netgears IP address into the verizon router's DMZ.
If that doesn't work, try the orbi in access point mode.
- CorrectTangeloMay 15, 2022Aspirant
Thanks plemans ! This is really helpful. You're spot on about the VZN routers and bridge mode - its not as easy/straightforward as one would think it is, and according to this post it looks like I missed a few steps. I'm going to try adding the Orbi IP to VZN routerDMZ and if that doesn't work, I'll give AP mode a try. Thanks again and I'll post here once I figure it out.
