CorrectTangelo
May 15, 2022Aspirant
Cannot Access Remote Plex Server - Unsecure Connection Error
Hello, Hoping someone can offer suggestions on how to troubleshoot this. I just upgraded my home Wifi to a Netgear RBK853 Orbi and I'm no longer able to access my remote Plex Media Server. When ...
CorrectTangelo
Hi Mikey94025 , Thanks for the response here! This might be a stupid question, but my Plex server is hosted externally and is not in my LAN. Do I still need to set up port forwarding in the Orbi RBR?
Apologies for my confusion, I've seen a ton of info and posts from people setting up LAN port forwarding so they can access their home Plex servers remotely. Haha, I'm trying to do the opposite - access a remote Plex server from my home.
Also, thanks for the link to the https://canyouseeme.org/ tool - that's awesome!
Mikey94025
May 15, 2022Hero
CorrectTangelo wrote:Hi Mikey94025 , Thanks for the response here! This might be a stupid question, but my Plex server is hosted externally and is not in my LAN. Do I still need to set up port forwarding in the Orbi RBR?
OK, no you shouldn't need any port forwarding if you're not trying to open up access to something on your home network. Outgoing connections should work just fine.
Sorry, I'm not a Plex user so don't know what could be wrong and caused by upgrading to the Orbi. There are a bunch of reddit posts returned by google search. Perhaps try overriding the Orbi's DNS settings to `8.8.8.8`, or try toggling Plex security setting from `any` to `required` and then back to `any`.
