prwalker
Nov 10, 2024Aspirant
Cannot add RBS750 satellite
I have an ORBI RBR750 router with one RBS750 satellite. I am trying to add a second RBS750 satellite. The new satellite appears to sync -- turns blue -- but the network cannot find it as a satellite....
- Nov 13, 2024
Ok ya if you can get to the log in using the assigned IP address, log in should be admin and password is all.
Have the RBS FW file downloaded to the PC and unpacked from the .zip file and then once on the RBS WEB page, you can send the .chk file directly to the RBS.
