grady7
Dec 11, 2020Aspirant
Cannot connect LG TV to orbi RBR 850 wi-fi
Hi, I just bought a new LG 4K TV, and it will not connect to my orbi network (AX 6000). I have googled like crazy. I called LG - was able to connect the TV to a phone hotspot. I checked the...
- Dec 12, 2020
luckily best buy will take it back no questions asked. the samsung is only $40 more - and a better TV - so I think that's the safe route.
I was just trying to be cheap, since an outdoor TV in Florida is a 2-year bet if you're lucky.
Regardless, you guys have been incredibly helpful. I'm picking up the other TV later today, so I'll let you know the end of the saga.
Dec 11, 2020Guru - Experienced User
Yes. Lets try this quick test to see if the TV will even connect at all. Just a quick test. Set the RBRs wifi security setting to OPEN or Disabled. See if the TV will connect then. After checking this, go back in and re-enabled WPA2 and AES.
Let us know the results.
grady7
okay - that's odd.
it connected to the orbi network for the first time, but it wouldn't stay connected. It seemed like the connection was unstable, but I have other wi-fi enabled devices right near there.
I reenabled the WPA2 / AES
