bhsharp
Feb 26, 2021Aspirant
Cannot connect RBS850 and RBS750 satellites to RBR850 as soon as I put it in AP mode
Wow, even entering this question felt like navigating a maze - the "model #" dropdown doesn't have any of the literal model#s like RBR850 or anything, you have to figure out that they want you to ent...
bhsharp
Also, to add: The setup for adding satellites says to plug them in and "wait two minutes until the light is solid white." That never happens; the light flashes white forever, or sometimes after many minutes turns magenta.
After factory resets this is super weird to me - these things aren't behaving even remotely like what the UI says they should.
Also, how on earth is it possible they can't pair to the router when they're 6 inches away and hardwired to it via Ethernet?
