bhsharp
Feb 26, 2021Aspirant
Cannot connect RBS850 and RBS750 satellites to RBR850 as soon as I put it in AP mode
Wow, even entering this question felt like navigating a maze - the "model #" dropdown doesn't have any of the literal model#s like RBR850 or anything, you have to figure out that they want you to ent...
W1lliam
Apr 20, 2021Virtuoso
You will need to keep that Ethernet for RBR850 on its WAN/Internet port (even when RBR850 is configured as AP mode) so connected Satellites can access to Internet via RBR850.
- bhsharpApr 20, 2021Aspirant
If I connect the incoming internet to the WAN port, won't the RBR850 create its own subnet?
I specifically want to use the RBR850 and satellites to *extend* an existing LAN so that devices connected to the upstream router and devices connected to the orbi satellite can all see each other directly.- W1lliamApr 20, 2021Virtuoso
once RBR850 is configured as AP mode, it stays on the same network as your main router, RBR850 no longer providing DHCP service in that case.
Good to know - but regardless of where I plugged the incoming ethernet cable into, once I put the router in AP mode, I couldn't get the satellites to connect to it at all. Even with no internet connection plugged into it at all. It just seems like when the router is in AP mode, satellites don't connect to it at all.
