dchartier
Aug 05, 2024Aspirant
Cannot connect to new devices or HomeKit on Orbi RBRE960
I bought an Orbi 960 (model RBRE960) a couple months ago and initially my Philips Hue gen 2 bridge, Hue bulbs, and Ecobee thermostat connected fine and worked over HomeKit fine. I have a set of Nanol...
Aug 06, 2024Guru - Experienced User
What region are you located?
Does this still happen with Access Controls disabled?
Is SPC or Armor enabled by chance?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
dchartier
Aug 06, 2024Aspirant
First, thanks a bunch for your help. I remain perplexed.
Chicago, IL, USA
I haven’t tried that. I thought I need Access Controls enabled in order for devices on my network to find and interact with each other. Did I misunderstand this feature?
Neither are enabled
Modem is an Arris BGW210 for AT&T Fiber, but why would the internet connection matter? I’ve had fiber service and this modem for ~ 3 years now, and didn’t have these problems with my previous TP-Link router (I forget the model. It had 5 or 6 antennas you could tilt)
All cables are brand new since I had that suspicion a while ago
None, just the main Orbi 960 unit
~ 2100 sq ft single family home with two stories and a finished basement, so around 700 sq ft per floor
What is the distance between the router 📡and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
- No satellites
- Router and Hue bridge are connected via Ethernet and barely 1 ft away
- Ecobee thermostat is maybe 4-5 feet away hanging on a wall with full line of sight
Yes, since the Hue bridge is wired and Ecobee wireless
When I wrote this yesterday, I had two modes of wireless: the main one which I guess runs 5Ghz and 2.4Ghz, and the separate IoT-only option running just 2.4Ghz. I tried more troubleshooting last night and turned on the 6Ghz-only line as well to try and further segregate devices in case that would help. It didn’t.
I did partly try this yesterday but only with unplugging the modem for a few minutes. I didn’t try unplugging the modem as well since I didn’t think it affected anything here. But if you really believe it could be a culprit, I can try that today
No, but now that you mention this idea I think I just want to try that; nuke all my router and wireless settings from orbit and start over. Thanks again, I might try this in a bit.
- FURRYe38Aug 06, 2024Guru - Experienced User
Chicago, IL, USA
No, Access Controls are not needed for devices on network to interact with each other.
Neither are enabled
What mode is the BGW210 working in? Gateway router or has it been bridged any?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.All cables are brand new since I had that suspicion a while ago
There should be markings on the cables indicating kind of CAT#.
What is the size of your home? Sq Ft?~ 2100 sq ft single family home with two stories and a finished basement, so around 700 sq ft per floor
What is the distance between the router 📡and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.- No satellites
What channel configurations are currently set on the router?When I wrote this yesterday, I had two modes of wireless: the main one which I guess runs 5Ghz and 2.4Ghz, and the separate IoT-only option running just 2.4Ghz. I tried more troubleshooting last night and turned on the 6Ghz-only line as well to try and further segregate devices in case that would help. It didn’t.
Channel configurations is what channels is 2.4 and 5Ghz using? I.e. Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Something to try for both modem AND RBR.
Has a factory reset and setup from scratch been performed since last FW update?No, but now that you mention this idea I think I just want to try that; nuke all my router and wireless settings from orbit and start over. Thanks again, I might try this in a bit.
Yes please try this if any of the above fails to correct this.
