dishbai
Oct 28, 2022Aspirant
Cannot connect to Open VPN on RBR350
Just picked up an RBR350 set. Everything's installed fine so far, speeds are great. However I'm struggling to get the Open VPN working. Have set up an account with no-ip, which all seems to be wo...
Oct 28, 2022Guru - Experienced User
Not sure if this is helpful:
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/RBK352-OpenVPN/m-p/2186004
dishbai
Firmware reports as V4.4.1.29 3.10.80.
Unfortunately I can't see the manufacturer of the modem as its just a white box affixed to the wall with no details on the visible side. However its not a router, just a modem with a single port out to connect to your router of choice. Also, probably should have mentioned, with my previous router I was able to connect to both an open VPN and a wireguard server running on a Raspberry Pi, so I don't think the modem is blocking anything.
