Lightro
Jun 05, 2022Aspirant
Cannot hook up both satellites as wired backhaul
I have the rbr750 plus 2 satellites. If I plug one in via wired backhaul it will connect but when I connect both satellites with wired backhaul. One goes to 5ghz wireless backhaul. I have been trying ...
- Jun 06, 2022Post can be closed, resolved. Cat5e wall adapter was wired incorrectly… Ran a cable outside of the wall run and worked. Checked wiring behind wall and the orange pairs were swapped.
Jun 06, 2022Guru - Experienced User
Ensure both RBS and RBR FW is on same version of FW.
Is there a LAN switch in between the RBR and RBS by chance?
Check cabling for good operation. Swap LAN cables around. CAT6 is recommended.
First wirelessly sync both RBS to the RBR. Then after synced, ethernet connect the RBS one at a time. Try connecting the one that goes wireless first to ethernet and let it connect and check it's status for 5 minutes.
Swap RBS with each other to see if the problem follows or remains at the one location.
- LightroJun 06, 2022AspirantPost can be closed, resolved. Cat5e wall adapter was wired incorrectly… Ran a cable outside of the wall run and worked. Checked wiring behind wall and the orange pairs were swapped.
- FURRYe38Jun 06, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
