Lightro
Jun 05, 2022Aspirant
Cannot hook up both satellites as wired backhaul
I have the rbr750 plus 2 satellites. If I plug one in via wired backhaul it will connect but when I connect both satellites with wired backhaul. One goes to 5ghz wireless backhaul. I have been trying ...
- Jun 06, 2022Post can be closed, resolved. Cat5e wall adapter was wired incorrectly… Ran a cable outside of the wall run and worked. Checked wiring behind wall and the orange pairs were swapped.
Lightro
Jun 06, 2022Aspirant
Jun 06, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
