PeterJGVDP
Sep 09, 2022Guide
Cannot integrate extra RBS850 to existing RBK853 mesh
Hello, I've purchased an additional RBS850 satellite to add to my exiting RBK853 system, when i connect this RBS to my RBR the led indicator turn blue, so there is a connection but this additional ...
- Sep 10, 2022Thank you for your reaction.
This is/was not the problem.
Complete system was/is wired backhaul.
How may satellites can be connected to the RBR, when it (the RBR itself) is in AP mode?
I've performed a complete new setup of the system.
In the beginning the RBR is in router-mode, and all the satelittes are connected the right way, they are all (3) synced.
But when i put the RBR in AP mode, one sattelite will not connect the right way, it is out of sync.
So i connected first one rbs (when RBR is in AP mode) and synchronized it, than i turned of the power of this rbs (nr. 1), than i connected nr. 2 and also nr. 3 and synchronized them also. When nr. 2 and 3 where connected (up and running) i powered up nr. 1 (it was allready synchronized before) all the 3 rbs are synchronized now. And problem solved!
Sep 09, 2022Guru - Experienced User
Its got an ip address. Are you able to log into that address to check its firmware version? (and update it if needed)
- PeterJGVDPSep 09, 2022GuideYes, ive updated it to the same firmware version as the other devices.
- plemansSep 09, 2022Guru - Experienced User
So you've got it updated. After the update, did you try factory resetting the satellite and re-syncing it?
I notice it says its wired in. Is it directly connected to the orbi or is it running through a switch?
If so, what switch is it?
Yes i have reset the satellite after the FW update, there is no switch between te RBR and the RBS.
This problem has happened before, with a different RBR and also a different RBS, they where also connected by STP wire (a completely different setup).
When i look in the webpage of te RBR it says the Backhaul is out of sync (see picture).
