PeterJGVDP
Sep 09, 2022Guide
Cannot integrate extra RBS850 to existing RBK853 mesh
Hello, I've purchased an additional RBS850 satellite to add to my exiting RBK853 system, when i connect this RBS to my RBR the led indicator turn blue, so there is a connection but this additional ...
- Sep 10, 2022Thank you for your reaction.
This is/was not the problem.
Complete system was/is wired backhaul.
How may satellites can be connected to the RBR, when it (the RBR itself) is in AP mode?
I've performed a complete new setup of the system.
In the beginning the RBR is in router-mode, and all the satelittes are connected the right way, they are all (3) synced.
But when i put the RBR in AP mode, one sattelite will not connect the right way, it is out of sync.
So i connected first one rbs (when RBR is in AP mode) and synchronized it, than i turned of the power of this rbs (nr. 1), than i connected nr. 2 and also nr. 3 and synchronized them also. When nr. 2 and 3 where connected (up and running) i powered up nr. 1 (it was allready synchronized before) all the 3 rbs are synchronized now. And problem solved!
PeterJGVDP
Sep 09, 2022Guide
Yes, ive updated it to the same firmware version as the other devices.
Sep 09, 2022Guru - Experienced User
So you've got it updated. After the update, did you try factory resetting the satellite and re-syncing it?
I notice it says its wired in. Is it directly connected to the orbi or is it running through a switch?
If so, what switch is it?
- PeterJGVDPSep 09, 2022Guide
Yes i have reset the satellite after the FW update, there is no switch between te RBR and the RBS.
This problem has happened before, with a different RBR and also a different RBS, they where also connected by STP wire (a completely different setup).
When i look in the webpage of te RBR it says the Backhaul is out of sync (see picture).
- plemansSep 09, 2022Guru - Experienced User
Is it able to sync when connected wireless?
- ekhalilSep 10, 2022Master
PeterJGVDP wrote:.........
The problem is that the satellite is not synced with the router, that's why it still has own SSID and own management password, .....
- You need to make sure to complete the sync. Please make sure the cable connecting the satellite is not the issue, if you can bring the satellite near the router and connect it with a short working cable.
- Press the sync button on the satellite and the router and wait until the led on the satellite turns blue. Repeat the procedure until you see that the satellite connection is "Good" and you don't see any longer the status "Out of Sync".
- PeterJGVDPSep 10, 2022GuideThank you for your reaction.
