Chuck_M
Oct 12, 2023Mentor
Cannot log onto Satellite (RBS-850)
My Orbi network consists of an RBR-850 router and 3 x RBS-850s. They work fine, but.... I cannot log onto one of the satellites... It is connected, is working, but when I go to the IP address...
Oct 13, 2023Guru - Experienced User
And does admin and "password" work for the log in?
I presume you updated all RBS manually by using the FW file and the RBS web page to update the FW on the RBS?
And this happens with all other browsers? MS Edge or Fire Fox or Opera?
Chuck_M
Oct 13, 2023Mentor
It does not accept any username/password including my systems nor admin/password
I have tried it wirelessly, hardwired, reset, rebooted and it does not act like the other two RBS's.
It was updated to current firmware via manual update when -- for a short moment -- I could log onto the satellite yesterday and then it went ghost again.
Like I said, the satellite works, I just cannot log on to it.
I wonder if something inside of the satellite has failed.
No other browser works. Firewalls, etc disabled.
Two work fine, this one does not.
- FURRYe38Oct 13, 2023Guru - Experienced User
Wow. Ok, last resort would be to do a 30-30-30 reset on the RBS.
Sounds like the creds are not getting populated or something in nvram is corrupt for this log in and creds area.
Or try a factory reset on the RBR and setup from scratch with this 3rd RBS.
- Chuck_MOct 13, 2023Mentor
And magically it is working again. Will keep an eye on it.. perhaps a synch issue or something that needed catching up, but all appears to be working perfectly now.
Thank you for your help.
Ok. May need a full FR and new BH. I've noticed that RBS seem to need a bit of time to fully get settled in.
Hopefully will keep working from now on out.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
